93 KQ 400/ BATTERY???
Old Dec 26, 2006 | 08:25 PM
Fatz's Avatar
Default 93 KQ 400/ BATTERY???
Once again ...Im trying to change battery but honestly I cant find the fn thing...I looked inside all wheel wells and under the seat please help the mentally challenged...drain plug to drop old oil ????location? I found the add spot....lol
Old Dec 26, 2006 | 10:06 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
It's up front - remove the plastic cover that is under the front rack that acts as a trim kit for the headlights. The battery is in a well up there.
BTW, it's considered a KQ300 - actually a mighty 282cc's.
Oil drain = There is a stock skid plate under the engine - look for a hole just back of center - the drain plug is recessed in there.
Jaybee
Old Dec 26, 2006 | 11:02 PM
Fatz's Avatar
Thank you once again for the knowledge and weird huh about the cc's on title it says 400 but nobody could tell me much about this bike in its actuality thank you. pulling over this thing is a bitch.....by hand!
Old Dec 27, 2006 | 12:37 AM
Well then I'll add another tip: The KQ has a compression relief lever on the top of the cylinder, just push it down while gently pulling the pull start to find TDC, then release it and pull start.
Jaybee
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
