Mikuni carb rebuild
Old Jan 2, 2007 | 07:55 PM
jmoffett's Avatar
Default Mikuni carb rebuild
I have a fuel delivery problem with my '97 King Quad and the local shop suggested I remove the carburetor (Mikuni 19B9 1 K712) and clean it. I've removed it but I don't know how far to try to disassemble it to clean it. Any suggestions?
Old Jan 2, 2007 | 08:28 PM
Doctorturbo's Avatar
GOT BOOST!
What was the problem? Describe it in detail. It will matter for what you want to look at in the carb.
Old Jan 2, 2007 | 08:59 PM
jmoffett's Avatar
It became very hard to start. I could choke it and get it started, but it had no throttle response. I could build the revs if I brought the rpm's up very slowly, and when I got it revved, it would blow dark smoke out of the exhaust. It seemed to me that it was loading up.
Old Jan 2, 2007 | 09:31 PM
GOT BOOST!
I would just take the float bowl off and see what's in there. Since it idles good I don't think there is any reason to go into the pilot jet.
Also make sure the float is free and does not hang up as any point.
Get a good can of carb cleaner and blow out all the passages.
Good luck and hope you get it running right.
Old Jan 2, 2007 | 11:45 PM
jmoffett's Avatar
I didn't mean to imply that it idles. It will only stay running if I keep feathering the throttle. What would need to be done to the pilot jet? Thanks.
Old Jan 3, 2007 | 12:46 AM
GOT BOOST!
I see. Just take it out and make sure there is no debris in it.
Old Jan 3, 2007 | 05:26 PM
jmoffett's Avatar
Thanks for your help.
GregM
Mar 6, 2018 06:53 AM
kelleycully
Sep 15, 2016 02:57 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
yambam13
Jul 4, 2015 01:49 PM
