Cracking Noise???
Old Mar 13, 2007 | 01:17 PM
MakeMeFast's Avatar
Default Cracking Noise???
when i turn either way or rock the quad side to side i get a cracking noise in the rear endn somewhere. anyone know what this might be??
Old Mar 13, 2007 | 09:52 PM
Stainless's Avatar
Have you checked your rear end bearings? Block the back up off the ground and wiggle the rear end to see if there is any slack.
Old Mar 14, 2007 | 12:03 AM
MakeMeFast's Avatar
yeah i checked the bearings and there is no play.
Old Mar 15, 2007 | 12:02 AM
mucky's Avatar
sounds like bearings to me. when you have the axle of the ground does it make noise when you roll it?. the bearing can have no play in then and still be bad. I had to replace mine once, everytime it was moving you could hear the bearing cracking and grinding. also check your swingarm bushings and sprocket hub and wheel hubs for being loose
Old Mar 15, 2007 | 12:07 AM
MakeMeFast's Avatar
everything is fine when i have it blocked up, its only when i am riding
Old Mar 15, 2007 | 03:15 PM
deanz400's Avatar
had swing arm bushing go out before ,
Old Mar 15, 2007 | 09:18 PM
bradr's Avatar
its probably the swingarm bushings. i had the same problem in my z250 until i changed them.
Old Mar 16, 2007 | 02:54 PM
MakeMeFast's Avatar
ill check thanx
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
