LT250 Light Out
Old Mar 22, 2007 | 01:55 PM
elsleepster's Avatar
Default LT250 Light Out
Well after changing the fluids and checking everything out on my 85 Quad Racer I noticed my headlight isn't working.
I checked and the bulb is good. Any suggestions on where to start looking for the problem?
Old Mar 22, 2007 | 10:48 PM
1987LT250's Avatar
trace the yellow wire with stripe coming from the light all the way to the flywheel cover, get down there check your source coils under flywheel.
Old Mar 24, 2007 | 07:40 PM
Okay, I had to take the fenders, tank etc. off- I've started looking for any loose wires or connectors. Haven't found anything obvious yet. I left my manual at work- could the CDI unit or regulator/rectifier have anything to do with it?
Old Mar 26, 2007 | 10:04 PM
sblt500r's Avatar
test the stator. the yellow/red wire should have about 1 ohm
Old Apr 1, 2007 | 11:28 PM
Well the good news is that I finally got the light working. Apparently the previous owner had for some reason snipped the 2 wires (R/Y & Gr). The manual calls for those 2 wires coming from a lighting switch that my quad (85 LT250R) doesn't have, just the dimmer and engine stop switch. I was reading an article about 3 years old and the guy said he had to connect the 2 "extra" wires together and his light worked. So I thought what the hell- just hoping I wouldn't fry something??? And the light came on and worked just fine- Hi & Low beam!
Hopefully it will continue working....
Thanks for all your input and help.
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
