Z400 Spark Plug???
Old Mar 23, 2007 | 10:57 AM
JkAss's Avatar
Default Z400 Spark Plug???
Which Spark plug would be best for my 2006 LTZ400 at sea level/ So Cal desert, the CR6E, CR7E, CR8E or the CR9E? Thanks in advance.
Old Mar 23, 2007 | 03:49 PM
DVXDUDE's Avatar
whats your manuel say??? it came with the cr7e right???
i've ran cr8e before, got a 7e in right now though
i would stick to the 7-8 area unless told differently
Old Mar 23, 2007 | 07:20 PM
mucky's Avatar
it came with the 7e in it, if you change to a higher compression then use the 8e for the higher octane fuel, just remember the higher the number the colder the plug
Old Mar 28, 2007 | 01:07 PM
kawiking's Avatar
why 8e for higher compression ??
Old Mar 28, 2007 | 06:51 PM
theCATman's Avatar
Because the higher compression is building more heat. So, a colder plug will help out with any possible knock.
Old Mar 28, 2007 | 08:38 PM
kyledc18's Avatar
if your going to be doing a lot of high speed riding use the cr 8
i also used one of those new fancy plug from ngk in my z, iridium i think there called, it worked good
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
