ltz250 won't idle
Old Mar 31, 2007 | 06:56 PM
Rca1965's Avatar
Default ltz250 won't idle
I have a 04 ltz250 that won't idle, it will idle real high sometimes then idles low and dies sometimes, when it is idleing it will just die, just like you just hit the kill switch, it will die whether it is idling high or low. i removed and disasembled the carb and cleaned and blew out everything, and still the same. i sprayed carb cleaner all around the carb and boot while it was running to see if there was a leak and found none. Thanks, Russell
Old Apr 1, 2007 | 02:04 PM
Rca1965's Avatar
Found the problem, idle mixture screw was 1.5 turns out, turned it to 2.5 out and it idled better, went to 3 out and it idles like new. does anyone know where it is usually set from the factory, bike is completly stock, wifes bike and she say no go fast parts. Thanks, Russell
Old Apr 12, 2007 | 02:35 PM
bradr's Avatar
its usually 2 turns out
Old Apr 12, 2007 | 09:43 PM
Brhodsie's Avatar
i have a z250 and not that this may not help but i think its supposed to idle somewhere beetween 1400 and 1600 rpms.
i also turnerd mine dopwn when i got it becuase i didnt like how high it was i probably turned it down 2.5 turns.
Old Mar 15, 2009 | 04:23 PM
55CGas's Avatar
Please school me on this. Mine won't idle low and I am hoping this is the problem. Where is the screw? Thanks,Mike
Old Mar 17, 2009 | 03:24 PM
NewportHillClimber's Avatar
the screw is on the bottom of carb where the bowl is indented pointing downward. it should have a rubber plug over top of it if its never been removed
Old Mar 17, 2009 | 05:13 PM
55CGas's Avatar
Whats the black **** with the rubber hose going into the carb???
Old Mar 18, 2009 | 03:19 PM
thats your idle adjust screw
Old May 29, 2017 | 08:28 AM
Joeownedyou's Avatar
Default Ltz 250 won't idle x2
Just bought one and the carb was gunk ed up by ethanal. Cleaned all jets, got it started and it is a hard start. Have to choke it and idle adjustment needs to be at like 1 turn. When it starts, it's at high idle so I turn the adjustment all the way out and idle goes down but not to normal, still to high. Played with and found that if I put my hand over the intake to restrisked the air, it will go to a perfect idle for 10-15 seconds and it goes back up if I don't keep my hand there. It revs up perfect, just the idle and starting. If I shut it off, I have to start all over again. It does not have an air filter yet, i just ordered one. Help!
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
