just bought a LTR450
Old Apr 1, 2007 | 05:46 PM
richwynn1's Avatar
Default just bought a LTR450
i want to put a cherry bomb, full exhaust not sure what kind yet. and a k and N air filter do i have to buy a computer thing so it doesn't run lean or what is up?
Old Apr 1, 2007 | 06:02 PM
bombrider04's Avatar
Welcome to the forums and wish ya luck with your 450...How do you like her sofar?..Well if you are getting a cherry bomb you will not need to get a computer as that is the computer and you can just gut the baffles of the stock exhaust and get yourself an airfilter, but I would stick with the foam to be honest...I love K&N's until I heard of them allowing too much dirt get through and ruining 450r's because the dirt sticks on the valves and bye bye engine...So take out the baffles, foam filter, and a cherry bomb and you should be seeing some good gains...Make sure you keep up with maintanance with the 450 as they are high tech machines and keep a log of how long you road the quad and maintanance etc...On my Honda I change my oil about every 5 hrs, but it also takes less then a qt of oil and I also change my tranny fluid about that often which I believe you won't have to worry about...Just keep up with it and it should be a reliable machine...Wish ya luck.
Old Apr 1, 2007 | 06:04 PM
I forgot to mention you can take the airbox lid off when you get the cherry bomb, but check the airfilter regularly to make sure shes clean.
Old Apr 2, 2007 | 11:23 AM
LT80's Avatar
LT80 Expert
Congrats on your purchace. It's a great machine.
I like the yoshi pipe. It's fairly quiet.
Filter: K&N is fine but Sparks (and others) make a foam filter to put on over tha K&N. It's a good set-up!
If not the foam, a "outerwears" is a must have over a K&N.
Have fun on your LTR! :
Old Apr 2, 2007 | 11:58 PM
Jaramie's Avatar
check out my ltr 450 bro...the hmf exhaust is amazing so i would recommend that.....just make sure you take care of your ltr and you'll be fine!!!
Old Apr 3, 2007 | 11:20 AM
DuneRider4ever's Avatar
Ya, that hmf system looks pretty hot on ur ltr [img]i/expressions/face-icon-small-happy.gif[/img]
COFatboy
May 2, 2020 12:06 AM
Jordanl6112
Aug 3, 2015 10:19 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
carolinabomb
Jul 26, 2015 08:40 AM
