LT250r engine cases sealant??
Old Apr 26, 2007 | 07:29 PM
BrianCMiller's Avatar
Default LT250r engine cases sealant??
Anyone know where and what type of sealant I should use to reaseal my engine cases on an '86 LT250r?
I just replaced the crank seals on both sides but when i was disassembling the motor i found one of the case bolts around the crank was backed out about 3 threads. This would explain the poor and sometimes surging idle after cracking the throttle right?? You could see where the mating surfaces were wet where gear oil was perhaps getting in as well. Any help is appreciated.
Brian C. miller
Harrisburg, Pa.
Old May 3, 2007 | 10:31 AM
nevermind.............I used permatex 83h.
-B
Old May 4, 2007 | 10:40 PM
sblt500r's Avatar
i use hondabond. but a yamahabond or suzukibond works just fine.
SDR-II
Sep 29, 2015 01:06 AM
ghost civic
Jul 19, 2015 10:13 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ghost civic
Jul 15, 2015 10:48 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
