Eiger running to rich
Old May 11, 2007 | 01:16 PM
Krychezk's Avatar
Default Eiger running to rich
I have a 06' Eiger and I pulled the carb off because I was going to rejet it but I couldn't find the jets I wanted so I just cleaned it and put it back on. Before it acted like it was runing lean but now it idles real rough and has black smoke coming out, I called a shop and they said it was running rich. I've had the carb off and cleaned it 3 times now and still the same thing I also have tried adjusting the mix screw from where it was (1 7/8 turns) down to 1/2 turn and all the way out to 3 turns and it still does the same thing. Has anyone had this problem or have any suggestions on what to try?
Old May 11, 2007 | 03:04 PM
theitdude's Avatar
Wow,
That is the first Topic I've ever read about an Eiger being too rich from the factory [img]i/expressions/face-icon-small-happy.gif[/img]
Since you've had the carb apart a few times, check to make sure the vent line running up under the seat behind the airbox snorkle is not kinked anywhere (or plugged with something)
Old May 11, 2007 | 03:09 PM
Krychezk's Avatar
Well I'm pretty sure it was running to lean but after I pulled the carb off it started running rich, I'm going to check the vent line tonite to see if that is the problem, Thanks
Old May 11, 2007 | 03:13 PM
Krychezk's Avatar
Also does anyone know were I could find a printable diagram of the carb so I can check and make sure everything is back together correctly
Old May 11, 2007 | 04:13 PM
theitdude's Avatar
Try these:
http://www.lonestaratv.com/informati...b%20clinic.htm
http://www.nightrider.com/biketech/hd_cv_mods.htm
http://www.gadgetjq.com/keihin_carb.htm
Old May 14, 2007 | 03:02 PM
Krychezk's Avatar
Well I found the problem, I some how lost the needle valve, must have blown it out when I was cleaning the carb. I just ordered a new one so I should be up and running by Memorial Day. Thanks for the links, I would have never knew that something was missing and I probably would have taken it somewhere to have it fixed.
Krychezk's Avatar
l
Old May 14, 2007 | 03:17 PM
theitdude's Avatar
Cool,
Glad the links were helpful.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
neilbedwell
Nov 10, 2018 11:02 AM
robj
Jun 15, 2015 08:45 PM
