Eiger auto drive belt cover
Old May 16, 2007 | 03:19 AM
Scott267839's Avatar
Default Eiger auto drive belt cover
does anyone know the size of the drain plug on the Crankcase cover? It is missing on my 2002 Eiger. Is there any reason to leave this out? I know why it should be there and when you would use it. But I assume it was not there when I bought the Eiger.
Scott
Old May 23, 2007 | 06:50 PM
RonV's Avatar
If you're talking about the one that drains water out of the CVT side, then it is the same size as the bolt that holds the bracket that's under the seat and above the battery. I'm sorry, I don't know the metric size of it. Another thing, though, I did shorten mine and use a washer that seals in case you drive in water/mud. Hope that helps. If I remember, I'll put a socket on it tonight and add a note.
Old May 23, 2007 | 07:55 PM
RonV's Avatar
It's 12mm. Like I said, you don't want the bolt to be too long and use a washer that will seal it.
Cummins Driver
Sep 11, 2019 01:22 PM
toonces
Jul 31, 2015 09:27 AM
baysport
Jul 23, 2015 11:37 AM
trouttracker
Jul 20, 2015 11:54 AM
ghost civic
Jul 15, 2015 10:48 PM
