z400 axle??
Old May 21, 2007 | 09:36 PM
bfastorblast's Avatar
Default z400 axle??
hey was wondering how hard it is to put an after market axle on (mine bent)
could i do it myself or do i have to bring it in thx
Old May 21, 2007 | 10:05 PM
mucky's Avatar
Default z400 axle??
very easy to do. remove the tires and hubs, unbolt the rear brakes and loosen the 2 nuts on the axle and it will slide right out
Old May 22, 2007 | 11:42 AM
bombrider04's Avatar
Default z400 axle??
Yea it is really easy just as he said...Mucky do they need to press the sprocket hub on for Suzuki's?..Then one you get thge old one out make sure you repack your bearing and inspect the rear while you have it apart and if everything is fine put t back together and make sure everything is tight.
Old May 22, 2007 | 10:51 PM
mucky's Avatar
Default z400 axle??
the sprocket hub slides off the splines on the axle
Old May 23, 2007 | 04:13 AM
xtremebanshee's Avatar
Default z400 axle??
yea man... its super easy. i bent mine. it took me a couple of hours to do it and i was taking my time.
what knid of axle are you going to buy???
NewGuy2481
Oct 6, 2015 05:54 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1000gade
Sep 9, 2015 04:41 PM
1ArmBandit
Sep 8, 2015 08:59 PM
