ltz400 clutch problem
Old May 20, 2007 | 04:04 AM
xtremebanshee's Avatar
Default ltz400 clutch problem
i just replaced my clutch in my 03 z400. it was the original clutch with probably 300 hours on it so i figured it was time to change it. anyways i bought a EBC clutch kit with heavy duty springs. i did it myself. first time ever doing it. asked a few people how to do it. took me a few hours. very easy to do. got on it and rode it. ran like a dream. took it to the track a few days later. no problems.
well friday i took it out for a little spin. the clutch was slipping. i just put it up for the day cuz i was so mad this was happening. the next day i was going to the track. looked through the manual and it said to adjust the clutch lever. i did that and it stopped. took it to the track. rode it for a couple of hours. then it started to slip real bad. i tried to adjust it again but no use. never got it to stop.
what do i do? is there anything that i can do or look for? the clutch only has about 6 hours on it.
PLEASE HELP!!!!!!
Old May 20, 2007 | 10:20 AM
ZButcheR's Avatar
DId you soak your fiber plates in oli for 15 to 20 hours befor you installed them???
Old May 20, 2007 | 01:06 PM
the kit said to soak them for a few hours. i soaked them for about 5 hours....
Old May 20, 2007 | 05:31 PM
mucky's Avatar
check the clutch basket for wear. if its worn enough the clutch plate might be hanging up on them, or a worn or distorted pressure plate or clutch plate
Old May 21, 2007 | 01:34 PM
when i put the new clutch kit in, i looked at the clutch basket and it looked good to my knowledge. is there something i should look for on the basket??
all my pressure plates and clutch plates are brand new. how would i have worn or distorted one so soon????
Old May 23, 2007 | 04:15 AM
any other advice for me.......
skinnyr6
Aug 25, 2023 02:18 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
cornermike
Jul 8, 2015 11:44 PM
