03 Z400 no spark
Old May 28, 2007 | 11:54 PM
2003 Z 400's Avatar
Default 03 Z400 no spark
03 Z 400 it cranks fine but no spark, I have been able to push start it a few times. Pushing it aint much fun. Any and all help would be great. Thanks.
Old May 29, 2007 | 12:47 AM
SpookySuzuki's Avatar
pull the plug out, start crankin it for about 10 seconds at a time with the plug OUT and the choke OFF, do this for about 6 to 7 times, put a NEW plug in, drain the old gas, put fresh premium in, make sure the choke is ON all the way, and it should fire up no problem for you...i had this type of problem here and there, but a new plug and fresh gas usually did the trick.... make sure you have the right plug, get a NGK: CR7E You'll be up & running in no time...
Old Jun 2, 2007 | 07:23 PM
mucky's Avatar
there is 5 things that cause no spark, 1 ignition coil, 2 spark plug,3 generator, 4 CDI , 5 pickup coil, I would try a new plug first
Old Jun 2, 2007 | 07:56 PM
2003 Z 400's Avatar
Thanks for the info. I changed the plug but it still will not start. I was able to pull start it though. After it was warmed up it would restart. I let it set for an hour and now it won't start again. I 'm still scratchin my head.
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
