Web cams or hot cams?
Old May 29, 2007 | 08:50 PM
crazy_z400's Avatar
Default Web cams or hot cams?
i was wondering if i should go with web or hot cams. i figured the best research was to ask people for their opinions. Anyone know the cost for web cams? Any comments are much appreciated.
Old May 29, 2007 | 09:28 PM
yellowrider250ex's Avatar
I don't know the cost of web cams but i do know they are alot better than hotcams.
Old May 30, 2007 | 02:03 PM
bradr's Avatar
i have a web cam in my bike and i love it. nice power difference. i suggest you also get valve spring kit from web cams if you go with them also. and they are relativly cheap.
Old May 30, 2007 | 09:32 PM
mucky's Avatar
one difference you need to think about is you buy hot cams new with no core charge and web cams you have to send your stock cams back as cores. they're both great cams, you can get different web cams for your motor not like hotcams. I run hotcams and they work great for me, I like being able to keep my stock cams in case i have a problem so Im not stranded waiting for a new cam
Old May 31, 2007 | 01:19 PM
bradr's Avatar
actually for a ltz400 you dont need to send your core back you can if you want it to be cheaper but web cams offer a brand new cam for that bike.
Old May 31, 2007 | 11:39 PM
cataway's Avatar
last test i seen showed the web cam just marginally better that hot cams .
Old Jun 1, 2007 | 01:03 PM
bradr's Avatar
still better though.
Old Jun 2, 2007 | 12:39 AM
Sandgod's Avatar
I just dyno'd two Yoshi 450z's. Both ported by the same builder running the same carb. One did have .5 higher compression then the other though. The Web cams were barely better and it was only in the mid range. The othe Yoshi has the old style hotcams.. I have dyno sheets of both on the Z400 site that is called central under the user name Sandstorm..
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
