1986 Suzuki Quadsport 230 fix up
Old Jun 14, 2007 | 07:37 PM
mikem92's Avatar
Default 1986 Suzuki Quadsport 230 fix up
Hello
I'm 15 years old and I plan on buying a 1986 Suzuki quadsport 230 tomorrow. The bike has not been ridden very much (It still has the stock tires and they are in good condition.) The bike runs and has somewhere around 50 hours on it. I grew up on a Yamaha Raptor 80 and I have been riding my fathers suzuki quadsport 400.
I need some help. I want to get this bike into the best running condition that I can. Can anyone suggest necessary pieces to look at/replace? Maybe ones that could be damamged from sitting in a garage for 20 years? I was told to take a look at the swingarm bearings and I will do that and if needed I will replace those. I get all the help I need from my father who has grown up on four wheelers.
Thank you
Old Jun 14, 2007 | 08:23 PM
270quadsportguy's Avatar
check swingarm bearings and axle bearings they are weak link and cause chain to throw breaking side cover and leaking oil
Old Jun 15, 2007 | 12:56 PM
mikem92's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 270quadsportguy
check swingarm bearings and axle bearings they are weak link and cause chain to throw breaking side cover and leaking oil</end quote></div>
Thanks! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 15, 2007 | 02:10 PM
jetmotoracer's Avatar
my freind bought the next year up and he had to get a new enjin because when he bought it he didnt know the chain snaped witch messed the whole thing up.....but he bought it used and that was a freek axedent...you might just have problems with findin parts if something brakes is all...go for it
Old Jun 15, 2007 | 03:42 PM
mud2sno's Avatar
Mike, I just rebuilt at 87 that was also not used in a couple years. I would check the bearings, and also clean out the carb if it has been sitting. Mine had a smoking problem so I had the head reground with new valves( the seals were bad) and replaced the piston. The bike starst on 1st kick and no more smoke.
Old Jun 15, 2007 | 06:04 PM
LTZGUY's Avatar
check the brakes, change the timing chain, clean the carb, wheel bearings, shock bushings, and charging system.
Old Jun 15, 2007 | 06:21 PM
mikem92's Avatar
Thanks for all the help guys!
Old Jun 16, 2007 | 11:40 AM
usry's Avatar
Replace the sprocket(get a 13 front 42 back!!!!!!!!!!!
Old Jun 16, 2007 | 01:20 PM
mikem92's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: usry
Replace the sprocket(get a 13 front 42 back!!!!!!!!!!!</end quote></div>
What would that do?
Old Jun 16, 2007 | 01:53 PM
LTZGUY's Avatar
TAKE OFF FASTER.
