Submerged Quadmaster 500....HELP
Old Jul 8, 2007 | 09:51 PM
khris's Avatar
Default Submerged Quadmaster 500....HELP
Hello,
I have been helping (doing all the work) my neighbor that put his 500 in the lake. Anyway, I have changed the oil 8 times with minimal improvement in the oil. Is there a second drain for the transmission / transfer case/ final drive?
It is running, but the oil is still milky after a few minutes of running.
I do not have a manual, and just want to help him. 8 oil changes should have fixed this.....I would have thought?
Khris
Old Jul 9, 2007 | 02:16 AM
270quadsportguy's Avatar
pull oil drain and let sit overnite id drain everything i could and let sit a day before refilling
Old Jul 9, 2007 | 03:21 AM
quadsport230's Avatar
everything needs a chance to dry out, let it sit dry for a day or two like 270QSguy said. i would check the differential oils too, check all bearings, etc
Old Jul 9, 2007 | 02:45 PM
khris's Avatar
OK, sounds like a plan. I just figured it would be clean by now...with 8 oil changes. I had a 460 Ford, jet boat sink, and in 3 oil changes it was clear and good to go. Maybe it had less water.
Thanks,
Khris
Old Jul 10, 2007 | 01:40 AM
yea it will probably need some luv once it runs 4 a while
switzomatic
Aug 24, 2015 12:57 PM
gspman
May 16, 2001 09:21 AM
Az4whlr
Jul 7, 2000 12:01 AM
drh19
Jan 11, 2000 04:36 AM
