LT250R Engine Overhaul
Old Jul 15, 2007 | 11:33 PM
RappinErnie's Avatar
Default LT250R Engine Overhaul
Does anyone know how much an LT250r complete engine overhaul would cost?
Thanks
Old Jul 18, 2007 | 04:23 PM
razrbakcrzy's Avatar
What't the quad worth to you? Are you talking about top end or top and bottom?
Complete $1200 to $1500. New transmission bearings and all worn tranny parts Check & replaced if needed, new clutch, new water pump, new reeds, resleeve or hone cylinder, new piston and rings, new rod bearings or new rod, crank bearings. all new gaskets and labor to do it.
Top end only, $500 new piston & rings, hone cylinder if still in good shape, new wrist pin and bearings, new set of reeds. All required gaskest and labor.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
ronnierhino06
Nov 9, 2015 12:56 PM
austinwhitton
Aug 11, 2015 06:21 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
