2005 Eiger help
Old Jul 22, 2007 | 07:56 PM
jnt3000's Avatar
Default 2005 Eiger help
While riding today i noticed a little play in the front wheel. I got home and took everything apart thinking it was the drive shaft. After putting everything back together i wiggled the disk break and there was still a little play. After looking at the manual i took the stearing nuckle back out and found out thats where the play was. Im not sure if i should just buy new seal and take it all apart and greese it all up and put it back together or buy the bearings to (trying to save a little money). It seams like the bearings are ok it still turns smooth. Also in the manual it shows you need special tool to take it apart has anyone done it before and can you do it without the special tools? Thanks for the help jeff
Old Jul 23, 2007 | 10:44 PM
jnt3000's Avatar
Quick update i pull the nuckle out and put it in a vice. I was able to knock out the seals and the bearings from the inside and it was dry as a bone. Any eiger owners my want to take a look and hit the bearings with some greese. looks like its going to cost about $45 each wheel to replace the bearings and seals.
Old Jul 24, 2007 | 12:10 PM
Krychezk's Avatar
I just changed the bearings on my 06' Eiger. I was surprized to find there was no grease in the hub and mud was actually packed in behind the seal. I filled the hub with grease before I put the new bearings in, hopefully this keeps some of the mud and water out. I was also thinking about getting a grease needle and tring to put some grease in all of the boots (tie rod ends, ball joints) cause they didn't fill like they had any grease either.
Old Jul 24, 2007 | 08:35 PM
jnt3000's Avatar
I just got one of those greese needles last week and it woorks great for the boot covers. Where did you get your bearings? I think im going to get the set of bearings and seals off of Ebay for 30 some Dollars.
Old Jul 25, 2007 | 01:19 AM
Krychezk's Avatar
I got mine from a place called Xtreme Suzuki I think I payed about $50. The kind I got were Pivot Works and they looked like much better bearings than came on the Eiger And they are sealed on both sides, the ones I took off were only sealed on one side and that probably didn't help when mud got in there. With new bearings and grease I'm hoping they will last longer (only got 500 miles out of the factory ones)
Old Oct 22, 2007 | 11:37 PM
ricoloff's Avatar
Hello,
I saw your grease posting and wondered where you bought the grease needle?
Thank You.
Old Oct 23, 2007 | 12:11 AM
250Redneck's Avatar
the bearings that you can buy from ebay are sealed on both sides. i got the bearings/seals to do both front wheel bearings and both axle bearings for my vinson for 65$ish a very reasonable price imo
Hunter
Old May 28, 2008 | 11:04 AM
RonV's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jnt3000
Quick update i pull the nuckle out and put it in a vice. I was able to knock out the seals and the bearings from the inside and it was dry as a bone. Any eiger owners my want to take a look and hit the bearings with some greese. looks like its going to cost about $45 each wheel to replace the bearings and seals.</end quote></div>
I realize this post is OLD, but could you expand on how you got the bearings out of the knuckle. I took both fronts off and on the left side, the ball bearings literally fell out. The right was bad, too. I was able to get them out of the left knuckle with a hammer and a chisel, but it took a while. How did you do it?
Old May 29, 2008 | 10:25 PM
greeneiger's Avatar
I would like to know to.
salixair
Nov 3, 2015 08:25 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
