Eiger Mixture
Old Aug 10, 2007 | 03:40 PM
greeneiger's Avatar
Default Eiger Mixture
Can somebody tell me where the mixture screw is located
Thanks
Old Aug 14, 2007 | 11:13 AM
Back40's Avatar
Eiger Carb pics
Old Aug 14, 2007 | 11:32 AM
greeneiger's Avatar
Thanks for the pics!!
Back40
I see you have a Dyno Jet Kit. What slot are you running on the neddle. Also do you just use the clip? What about the little washers ?
Thanks
Old Aug 14, 2007 | 01:14 PM
Back40's Avatar
I went with the clip on the 3rd notch from the top and 2 washers on top of the clip per the instructions.
Old Aug 14, 2007 | 02:01 PM
greeneiger's Avatar
Do the washers just sit loose on top ? Or did you lock them in with the other clip?
Old Aug 14, 2007 | 03:26 PM
Back40's Avatar
My kit only came with 1 e clip so my washers just sit on top of the e clip loose. Here is what my instructions state:
2. Install Dynojet needle on groove #3 for applications below 5000 feet, groove #2 for above 5000 feet, using all stock spacers. Install the Dynojet washers above the E-clip (Fig.A).
NOTE: the groove on which the e clip is attached is diff b/w standard trans vs auto.
Here are links to the instructions:
Standard shift - <a target=_blank class=ftalternatingbarlinklarge href="http://www.dynojet.com/pdf/Q310.pdf
">http://www.dynojet.com/pdf/Q310.pdf
</a>
Auto - http://www.dynojet.com/pdf/Q309.pdf
Old Aug 14, 2007 | 09:01 PM
greeneiger's Avatar
Ok I'll try it tomorrow
Thanks for your help!!
Old Aug 16, 2007 | 09:12 AM
greeneiger's Avatar
Well got everything put in last night and out for a ride. What a diff!!! Keeps pulling all threw the gears and barely falls off now going up hills. Lost a little top speed maybe 3-5 km/H but oh well. Hopefully it will start better in the cold this winter too. Also i don't think the fan comes on as much.
Old Aug 16, 2007 | 10:47 AM
Back40's Avatar
Cool
panicmanic
Dec 15, 2015 01:58 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
goosemasterkl
Aug 23, 2015 11:36 AM
baysport
Jul 23, 2015 11:37 AM
