vinson not running right please help!!!
Old Aug 13, 2007 | 01:47 PM
path5604's Avatar
Default vinson not running right please help!!!
I have a 2004 vinson 5spd the other day it was running ok just seemed like it wasnt getting full throttle, then a couple days a go it started this intermittent thing where it runs good one time and the next you can't hardly even rev it and it backfires, pops, etc. Please give me any suggestions
Old Aug 13, 2007 | 07:32 PM
kickervr91's Avatar
I have had the same problem with mine. You can try a fuel injection cleaner to help clean the carb. and if that doesnt work you will need to take it to a dealer and have them clean out ur carb. the problem is probably with old gas or at least that was the case with mine. Hope this helps.
Old Aug 13, 2007 | 07:42 PM
cedarbush's Avatar
pull the carb off and clean real well,take the jets out and use 2+2 carb cleaner through it.Then why don't you go to the auto parts store and buy a cheap inline filter for it for xtra good measure.That way any crap in the tank has a better chance of being stopped and not going in your carb.A little xtra protection.Hopefully this helps for starters,take care.
Old Aug 14, 2007 | 11:18 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Does it run better with the choke on? There's a small screen at the carb inlet. Remove the inlet fuel line and use a small soft wire while spraying some carb clean to clean it out. With the fuel line off, turn the petcock to Pri.. Fuel should flow freely. Cut the line in half and install a fuel filter. There's a small screw in the float bowl of the carb. remove it and hook the fuel line back up. turn to Pri again and let the fuel flow for about 30 secs. should flush the float bowl.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
