LTZ-400
#21
well, are you going to be doing any motor work on it ? if you are save up and get a full system. or you can just get the slip on. i have the yoshi and ive always liked t. i run the full system.they are all about the same in power,you need to look at the one's that arent going to fall apart. (white bro)
#22
Hey dude, I bought the yoshi slip-on and it works great throughout the powerband but I kept hitting the rev limiter when hitting the dunes at full throttle, so I installed a Rev Max CDI which increased the revs 700-1000 rpm. No more problm. Now I just ordered a K&N filter kit from Alba. I plan on installing it but I'm still not sure about the jetting. Good luck!!!
#25
<div class="FTQUOTE"><begin quote>Originally posted by: digdugg909
By the way, whatsup with "scooterpgtx quad patrol". Thats real sickening.</end quote></div>
So does this count as fan mail?
#28
if you dont wann spend money on the yoshi then you should go with CT or T-4 pro circuit my friend has the t-4 on his 400 and its pretty bad it puts more accel on it then a predator 500 has pricing also aint to bad either
