New guy here needs engine help!
Old Sep 29, 2007 | 02:43 AM
chad22's Avatar
Default New guy here needs engine help!
Hey all, my name is Chad. So anywho onto the question. i have a 86 quadsport 230. It has been sitting for about 3-4 years due to getting into my other toy(85 toyota 4runner rock crawler truggy) It has bad rings and a blown headgasket. i pulled it all apart about a month ago and got the top end rebuild kit. Now heres the delima, I am a mechanic, and i do not have any idea on how to time this bad boy, when taking the top end off i dropped the timing gear out of the chain [img]i/expressions/face-icon-small-mad.gif[/img] So what im in need of is the timing marks of it has any or a page out a FSM for this bike. Thanks a lot in advance [img]i/expressions/face-icon-small-cool.gif[/img]
Old Sep 29, 2007 | 08:58 PM
chad22's Avatar
nobodys got anything for me?
Old Sep 29, 2007 | 10:40 PM
OhHell's Avatar
I dont know about that particular model, But on most engines are fairly easy to figure out.
Most have a "T" and a "F" mark on the flywheel with a mark on the case to line it up with, and a mark on the cam gear with a mark on the head near the cam gear to line it up with.
If you find the marks, line the "T" mark on the flywheel with the mark on the case and while keeping it there line the mark on the cam gear with the mark on the head.
Old Sep 30, 2007 | 11:58 AM
albung's Avatar
there should be a O on ur top cam gear and behind ur left engine cover theres a lil ^u line up mark on flywheel . the top gear goes straight up,and both cam bolts should be flat across,i believe but not 100%
Old Sep 30, 2007 | 12:56 PM
chad22's Avatar
ok thanks guys, also how do i get the rings into the cylinder? is there a special ring compressor for this?
Old Sep 30, 2007 | 06:23 PM
OhHell's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: chad22
ok thanks guys, also how do i get the rings into the cylinder? is there a special ring compressor for this?</end quote></div>
I always just use my fingers.
Not always easy but with a little patience it has always worked for me.
Old Sep 30, 2007 | 07:24 PM
chad22's Avatar
Thats what i was doing and i got my self cought and ripped some skin off [img]i/expressions/face-icon-small-tongue.gif[/img] i guess ill keep trying that way then
Old Sep 30, 2007 | 10:44 PM
OhHell's Avatar
Forgot to say in my other post that I have seen people use radiator hose clamps with good results.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
