Coolant overflow on 2007 Suzuki ltr-450
I just got this quad and have about four rides on it. I noticed a little bit of coolant that had collected at the bottom of my skidplate on the last trip out. I did some pretty long and hard riding but it did not seem to have any overheating issues. I took it out today and noticed a pretty good amount of coolant puddled on the bottom of the skidplate. The coolant in the overflow resevoir is low. It appears the coolant is puking out of the overflow hose. Is this something that is common or do I have a problem? The weather was only about 60 degrees and I did not ride too hard [img]i/expressions/face-icon-small-happy.gif[/img] Thanks for the help!
I just got a new 08 ltr lnt ed 450 mine is doing the same thing exactly what you said i found when i jump it, what its doing is shaking to where it reaches the overflow tube iv talked to other guys at the track theres is the same way just let it get down low in the reservoir enough and it will stop leaking out, mine did it doesnt need alot of coolant in that bottle about an half to 3/4 of an inch from bottom up on bottle i also exteded the hose so it wouldnt leak on the chassie instead the ground .
jrooker6
Apr 23, 2016 07:36 PM
Sep 23, 2015 06:23 AM
Lou Domenech
Sep 11, 2015 06:35 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
