1987 LT300E
Old Nov 15, 2007 | 04:05 PM
joseph.lundy's Avatar
Default 1987 LT300E
does anyone have the electrical diagram and listing of the output for a 1987 suzuki LT300E. i am not getting any spark to the sparkplug, coil, i am getting current from the magneto but its 50 volts and i am not sure what would be causing this...please email me @ joseph.lundy@gmail.com for any info...thanks...
Old Nov 16, 2007 | 08:20 PM
JustRandy's Avatar
Default 1987 LT300E
Is 50 volts out of the ordinary? It should be unregulated voltage at the magneto. Do you have another coil from any other engine? A car, truck, moped, anything will do for a test. You can check continuity in the suspect coil with an ohm meter. I don't know what the values should be, but anything less than infinity or greater than 0 is encouraging. If the magneto, coil, pickup coil, and plug is good... You know what that means... [img]i/expressions/face-icon-small-sad.gif[/img] CDI
Old Nov 17, 2007 | 09:58 AM
Default 1987 LT300E
from what i was told the magneto should only be putting out 13 volts, but if its unregulated then i guess there isn't anything to worry about...however it isn't getting any juice to the CDI box either...i believe...
Old Nov 17, 2007 | 09:59 AM
Default 1987 LT300E
is there anyone out there that has an old LT300E that they want to get rid of for cheap...
Old Nov 17, 2007 | 11:58 AM
Default 1987 LT300E
is there anyone out there that has the shop manual for a 1987 LT300E and if so could you email me the electronics pages...
Old Nov 17, 2007 | 04:46 PM
JustRandy's Avatar
Default 1987 LT300E
If the regulator is hooked up when you take the measurements, 13 sounds ok, but if not then I would guess the voltage would go up as the rpms go up. I really don't know for sure.
In a few days I will have some repair manuals coming. They were shipped a couple days ago. Maybe there will be a diagram that will help.
Try to find the wire that supplies juice to the cdi. Then hook the red voltmeter lead to that wire and the black lead to the frame and see if there is juice getting to the cdi.
Old Nov 18, 2007 | 09:30 AM
Default 1987 LT300E
yeah there is juice to the cdi but i am not sure if its the right amount going either in or out...yeah man if you get those books and can give me some kind of idea of the different output readings from the stator to the coil maybe i can eliminate some things and finally decide whats causing the lack of spark to the sparkplug...i'm hoping its not the cdi but i am afraid thats probaly what its going to be...any help u can give me would be greatly appreciated...thanks
Old Nov 18, 2007 | 08:45 PM
JustRandy's Avatar
Default 1987 LT300E
I haven't seen much in the way of testing cdi's. Usually the process is to test everything else and figure the cdi is bad by elimination. I'm still wondering if your coil is good. Did you use an ohmmeter to check that out?
Old Nov 20, 2007 | 11:06 AM
Default 1987 LT300E
yeah...one of my buddies tested it but he doesn't thinks that the coil is receiving enough juice...but i guess i could just buy a coil and give it a shot...the day before it quit running i swamped the 4wheeler so it could have shorted the coil...it ran fine till i got it home and parked it...the next day when i went out to start it it wouldn't start...and the coil is not overly protected...i'll ask my buddy how much juice he got to the coil...thanks again...
Old Nov 20, 2007 | 01:43 PM
Default 1987 LT300E
ok here is whats going on 50amp ac coming out of the magneto, nothing out of the cdi, my friend said it could be the magnetic eye sensor but i am guessing its the CDI, do u know where i could buy a used cdi, or the magnetic eye sensor that reads the stator?
