1988 suzuki lt-f250
Old Nov 22, 2007 | 09:01 PM
brown1's Avatar
Default 1988 suzuki lt-f250
Can Someone Please Tell Me,How To Set The,Valve Timing,On A 1988 Suzuki LT-F250 Quadrunner?Thanks brown1joe@yahoo.com
Old Nov 24, 2007 | 07:00 PM
JustRandy's Avatar
Put the piston at TDC, either with a screwdriver down the sparkplug hole or by lining up the "T" mark on the flywheel with the stationary mark on the case. There should be an inspection hole for finding the "T" mark. Then make sure the cam lines are parallel to the head. If so, its timed right. If not, then loosen the chain and skip teeth until its right.
Valder
Nov 28, 2020 07:38 AM
VABrute
Jan 6, 2016 07:39 PM
merryman
Sep 19, 2015 03:15 AM
jsmit116
Sep 18, 2015 10:34 PM
Sep 1, 2015 11:59 PM
