LTZ-400 CHOKE STUCK PLEASE HELP!!
Old Jan 10, 2008 | 09:27 PM
Suzuki4U's Avatar
Default LTZ-400 CHOKE STUCK PLEASE HELP!!
The choke is stuck on my ltz400, I took the choke handle apart and tried to get it to turn off and tried taking it apart at the carb neither did anything. Anybody have any ideas the choke is stuck in the on position.
Old Jan 12, 2008 | 01:37 AM
pistonhed's Avatar
You have to unscrew the nut where the choke cable goes into the carb. Then you have to pull the plunger out of the carb,this can be difficult because they get stuck this is whats causing your problem.When you get it out take some very fine sandpaper and clean the brass plunger be careful do not mess up the rubber tip also use the sandpaper to clean the hole the plunger goes in.Use automotive sandpaper about #800 grit.Blow any debris out of the hole put a little oil on the plunger making sure it moves freely.Then screw it back together.If you need a breakdown of the carb go to MCmart.com in the carb diagram the plunger is part#26.If you like you can just buy a new plunger.
Old Jan 12, 2008 | 01:50 AM
Suzuki4U's Avatar
Thanks for the advice but, I actually found out the choke is not stuck it is working properly. The reason that I had thought the choke may be stuck was that I took it riding the other day after installing a k&n filter. It ran fine for the first hour or so, then we were bombin down a road and it really wanted to bog down in 3rd and when you came to a stop it would die. I pulled the plug and the plug was black which is usually a sign that it is running too rich...may it just be a sign I need to rejet it because of the k&n filter? If so any ideas which jet i should bump up too?
Old Jan 12, 2008 | 02:00 AM
pistonhed's Avatar
Most of the time when you go to an high flow filter such as a K/N you get a lean mixture this is from more air combined with the stock jet size,which will result in overheating and a white plug. What you are describing is just opposite of what should have happened.
Old Jan 12, 2008 | 09:20 AM
cataway's Avatar
ya sounds as tho you were running with the choke on. with the new filter and a open box rejet to a #142 main if and when ya go to a slipon pipe a bigger jet will then be in order , but with a stock pipe a #142 should work just fine
Old Jan 12, 2008 | 01:46 PM
Suzuki4U's Avatar
thanks cataway, with the new filter on should I always be running with the lid off? I live in Washington and ride in some pretty wet conditions, but I dont ever see myself submerging it in water deeper than the air box.
Old Apr 19, 2014 | 03:31 PM
GP_Rocks's Avatar
Heres my video to fix a stuck enricher choke plunger on a mikuni bs-29 carb like suzuki uses:
mrtidy
Feb 3, 2016 05:00 PM
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
Jackg17
Sep 26, 2015 09:30 PM
wrencher82
Sep 24, 2015 03:39 PM
