Eiger 400 4x4 question
Old Feb 4, 2008 | 10:49 AM
pmcc37's Avatar
Default Eiger 400 4x4 question
Hi I just got a 2003 Eiger 400 4x4 automatic, just traded it for a truck, are there any known problems with these particular machines.
Thanks in advance.
Old Feb 4, 2008 | 02:47 PM
BamaCraig's Avatar
I've got an 06 and have about 500 miles on with no problems. Just keep up the maintance and it should be trouble free.
Old Feb 4, 2008 | 02:50 PM
pmcc37's Avatar
ok, thanks, this one only has 338 miles on it, and starts and runs good, just wanting to make sure thier are any known issues with this quad, I'm fimiliar with alot of yamaha stuff, but not with Suzuki.
Old Feb 4, 2008 | 03:31 PM
Doug Anderson's Avatar
I have a 2003 with 600 plus miles on it. No problems to speak of, the only issue is the brake pedal sticks in place. Soon to be repaired.
Old Feb 4, 2008 | 08:15 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
About the only common issue is that many have had small pieces of plastic in the fuel system get caught up in the carb. Easy solution is to install an in-line fuel filter. I've had mine since '02 and it has just under 3,000 miles on it. Mine never had the fuel problem so I've never done the filter mod. Other than a loose nut on the autoclutch that made a strange noise when I first got it, I haven't had any issues that weren't just a maintenance thing. The Eiger is about as solid and reliable a bike as there is out there.
Jaybee
Old Feb 4, 2008 | 08:22 PM
BradW's Avatar
There are only two common issues that I've heard of. The first is that the older models have an issue with the fuel petcock on the bottom of the gas tank, which I believe was a recall. The other is a tendency for crud to get in the carburetor via the vent tube that runs up under the seat. This happened to me, but it was as simple as putting a piece of cloth over the end of the vent tube.
Old Feb 6, 2008 | 09:18 PM
greeneiger's Avatar
Good solid machine. All good advice. One other thing I've heard is the fan switch cutting out.
Old Feb 11, 2008 | 12:00 AM
Gerbil's Avatar
I have an '02 manual. 1500 miles on it. Never have had a single problem with it.
One of the best machine for the money.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
