Quadzillas's
Old Feb 14, 2008 | 09:07 PM
3&4wheelerdude888's Avatar
Default Quadzillas's
I have heard that zilla's blow up easy. Why is that? Can I avoid this catastrophe by a regular maintanence check-up or something? I would like to know because I might be getting one.
Old Feb 14, 2008 | 09:16 PM
PoolGod230's Avatar
2 strokes in general are higher maintenace and less reliable than a thumper. Higher RPM's etc, Tend to loosen everything up from vibrations.. Good luck with the zilla, scary fast! Wish I had one 15-20 years ago....................
Old Feb 14, 2008 | 11:20 PM
QWODER's Avatar
zillas aren't more prone to blow up than any other 2-stroke quads.They usually will not run longer than 4-strokes before you have to rebuild them.The 87 models are known for blowing head gaskets but that can be fixed from what I have been told.I have heard some guys with 87 models say they have never had any head gasket problems.
Old Feb 15, 2008 | 04:53 PM
Jeremiah25's Avatar
My zilla has never blown up. The only thing I've had trouble with is spliting primary drive sprokets. [img]i/expressions/face-icon-small-wink.gif[/img]
I've got an 87. I built a billet cylinder head for it, and installed oversized head studs, which I torque to 40 ft-lbs. It's never had a head gasket issue since the modification.
Old Feb 16, 2008 | 08:13 PM
JustRandy's Avatar
Sounds like a good read here http://www.dansmc.com/seizure.htm
Old Feb 17, 2008 | 06:00 PM
TomM's Avatar
Mine was a 87 it blew the head gasket even with oversized studs torqued higher than stock. Other than that though I didn't have any major trouble when I rode it. My friends was a 87 with a 90 motor he ran it way more than I ran mine. He ran it for several years almost every weekend. He replaced 1 piston due to wear and usually at least 2 bolts rattled out on any given day of riding regardless of loktite and or lock washers/ lock nuts. His was a better machine for most types of riding. Mine was insanely fast even made his seem slow. Would have been great for drag racing but I couldn't control it enough for any other type of riding. I think the bigger intake on the 87 cylinder really makes a difference in the power that motor can make.
Ashley S
Feb 18, 2024 08:56 PM
Levi Enstad
Sep 26, 2015 05:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ashley S
Aug 6, 2015 12:56 PM
FENDERBENDER
Mar 12, 2000 01:04 PM
