z400 mod questions
Old Feb 20, 2008 | 09:45 AM
zooooom's Avatar
Default z400 mod questions
What is everybody's opinion on mods for the z400 like big bore, cams(intake and exhaust or just intake). Mostly ride mountain trails with steep loose hill climbs. I'm looking for something that will help with having to slow down on a hill to get around rocks and roots and be able to get back in the gas hard and not choke. I appreciate any help.
Old Feb 20, 2008 | 10:01 AM
scootergptx's Avatar
Supersock
Hired Gun!
Honestly, a simple change of the front sprocket would help with the gearing. If you're just riding for the sake of riding, and not competitively racing, I wouldn't break into the motor. Pipe or maybe full exhaust system, K&N airbox lid, free flow air filter and rejetting would be all the motor work you should need.
But I see you've done all that, except for the sprocket change.
Tearing into the motor means less dependability. If you're really craving more power, a 450 or 700 Raptor may be the thing.
Old Feb 21, 2008 | 08:48 AM
zooooom's Avatar
A 450 is what I want but the money is stoppoing me. This thing runs pretty good right now. But the hills in the mountain are boogers and need more torque. Gearing down might be the first thing I do. Thanks.
Old Feb 21, 2008 | 10:40 PM
Yfzracer3a's Avatar
sell it and buy a 450 gona your gonna have the same power if you buy all the after market parts, for less money
Old Feb 22, 2008 | 10:49 PM
zooooom's Avatar
What's it worth?
Old Feb 23, 2008 | 02:01 AM
warrior226's Avatar
Drop down a tooth on the front sprocket first, see how that works. What $15?
Old Feb 24, 2008 | 03:47 PM
nimbh2's Avatar
get a little bigger carb
Old Feb 24, 2008 | 04:59 PM
cataway's Avatar
with the mods you show you should be at about 34 - 35hp, to get a little more
change out your intake air boot , should give you 2 hp any way. and another thing
you could do it put in a drz base gasket that will bump your compression up about a full point .if you do that change your rings as well.
the 13t is a very good idea especially if your going slow and around tight coroners
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
