Z400 suspension so hard my back hurts!?
I run 2pounds of air all around and have the rear shock preload as soft as it will go and compression damping soft. The shocks on the front of mine has no adjustments except for spring preload. I ground out the valley on the spring adjuster on the lowest setting to take all the preload off the spring and helped alot on the front. Do the newer shocks with adjustments on them make a difference in the ride?
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
400, adjust, adjustment, cushy, hard, ltz, ltz400, recommended, ride, sag, set, shocks, softer, suspension, z400
