Z400 starter clutch
Old Mar 28, 2008 | 01:39 AM
warrior226's Avatar
Default Z400 starter clutch
Wow that's cooked! I wonder what the heck happened? Looks like the drum may be OK though.
Old Mar 28, 2008 | 02:44 AM
nedflanders's Avatar
if you look at pic#2, there are 6 EMPTY bolt holes. ALL 6 of these allen-head bolts had loosened out of the starter clutch (drum), and were grinding against the stator. 5 of them were stuck to the stator magnets. not too sure how they got out in the first place tho.
Old Mar 28, 2008 | 02:59 AM
warrior226's Avatar
Maybe the loc-tite guy at the zuki' factory took the day off? What are you looking at, a new stator, plus the bolts? Could there be more pieces floating around inside the motor?
Old Mar 28, 2008 | 04:13 PM
it appears the motor is sealed from this area (just the crank end is exposed, and goes through a seal). I already ordered a starter ctutch from ebay, and now I just ordered a stator. so hopefully, I just swap out the parts. i would probably need some new bolts, but the replacement starter clutch assembly should already have these attached.
Old Mar 30, 2008 | 12:16 PM
  #15
upon closer inspection, those bolts didn't loosen off, they're ALL sheared off!!
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
ghost civic
Jul 15, 2015 10:48 PM
Jul 15, 2015 02:07 AM
