Eiger Shifting Hard
Old Mar 17, 2008 | 08:03 PM
13speed's Avatar
Default Eiger Shifting Hard
I have an 05 eiger with the 5 sp. trans. My problem is that the shifter seems to hang up every once in awhile and doesnt want to shift into the next higher gear very smoothly. Im not sure how to go about adjusting the clutch on this bike so I could use a little help. Does it sound like I'm on the right track? Thanks
Old Mar 18, 2008 | 01:59 PM
13speed's Avatar
Anybody?
Old Mar 19, 2008 | 01:40 AM
greeneiger's Avatar
it won't shift at all to the next gear? or is just hard? Does it do it when hot or cold?
Old Mar 19, 2008 | 10:29 AM
rolsmojave3's Avatar
Sometimes mine will do this too. I think you could modify the star wheel (part that the shifter uses to stay in a defined gear) but that would require some internal work. I tried synthetic oil and it helped quite a bit, but it will still do it from time to time. Try some synthetic oil in the bike to see if that helps.
Old Mar 19, 2008 | 04:09 PM
04Eiger's Avatar
I have an 04 5 speed and mine does the same.
I always thought that without a clutch, it would just do that some times. The gears have to line up. Mine only does it if I am pushing it, high RPMs and then try to shift or when under a load, like up a big hill, or though a mud hole.
Usually if I poke the throttle to even out the RPMs it shifts.
I would prefer a manual clutch to eliminate this problem. I am not aware of a 4 wheel drive that has manual shifter and clutch.
I like having full control.
I plan on looking at a CVT clutch for the next bike, since full manual is not an option with a 4x4 ATV.
Old Apr 1, 2008 | 10:18 PM
buck1992's Avatar
ive got a 06 and mine does it to but usually only when i jus came out the mud but usually i go take her through a creek and it cleans her off and i shifts smooth as butter also when i try to drag race with her she sometimes seems to get stuck so try acceleratin slower or if you get urs muddy try gettin it clean and see how that works out
Ridgerunner665
Sep 15, 2015 01:20 AM
bvolks
Sep 13, 2015 12:57 PM
essonlaker
Sep 10, 2015 01:12 PM
Elkaholic
Sep 6, 2015 02:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
