ltr exhaust
Old Mar 18, 2008 | 12:03 AM
bigal32690's Avatar
Default ltr exhaust
I just got a 08 ltr and im not sure what exhaust would be best. I want to get a full system. Ive looked at yosh. but the hp was only 3 more than stock. Ive also looked at DMC and Trinity and Alba. dmc and alba was putting out 49 hp, while trinity hit 51. (stock 43) (yosh 46)
Old Mar 18, 2008 | 04:45 PM
OffRder15's Avatar
Default ltr exhaust
Did you check out HMF?
Old Mar 18, 2008 | 08:13 PM
bigal32690's Avatar
Default ltr exhaust
yea I think it was the same as yosh.
Old Mar 18, 2008 | 09:50 PM
bigal32690's Avatar
Default ltr exhaust
i also need to find a efi controller that will go good with that exhaust. U CAN STILL PUT IN A JET KIT WITH A EFI CONTROLLER RIGHT??????
Old Mar 18, 2008 | 11:17 PM
OffRder15's Avatar
Default ltr exhaust
No jets cause its fuel injected. If you get the exhaust I'm pretty sure the Cherry Bomb is all you'll need unless you want to get pretty serious. The Cherry Bomb is only about $30.
Old Mar 18, 2008 | 11:27 PM
OffRder15's Avatar
Default ltr exhaust
This is from HMF's website:
HMF dyno and track testing has shown that by removing or modifying the air box lid, accessing the "race map" by using the HMF MAP KEY (or similar) you can expect these horsepower gains:
HMF SLIP ON: 11.0 HORSEPOWER OVER STOCK.
HMF FULL SYSTEM: 12.5 HORSEPOWER OVER STOCK.
HMF testing also shows that when using the "race map", the air box lid off and our slip on/system that recalibration of the air fuel ratio is NOT NEEDED.
NOTE: You MUST use the "race map", using the HMF MAP KEY or similar device is MANDATORY.
We did extensive track testing using a wideband data logger which records the AFR while running under different loads and conditions.
Testing was done in different gears and throttle positions on an MX track and a 250 foot long 40 degree angle hill climb course.
During these tests ("race map" airbox lid off and HMF slip on / system) the AFR remained in a safe range.
NOTE: The HMF MAP KEY is a plug in device that "tells" the stock ECM to use the "race map" it plugs into the stock wire harness in seconds, it gives you 500 more top end RPM, changes the fuel curve and timing.
NOTE: IF you DO NOT use the "race map" you run the risk of improper air fuel ratios which can lead to higher than normal internal exhaust temperatures. These high internal temperatures could cause premature failures.
NOTE: IF you plan on adding: high compression piston, big bore kit, camshaft or live in an unstable atmospheric condition area then we SUGGEST that you get the HMF OPTIMIZER EFI TUNER so that you can adjust the AFR for changing conditions.
The "HMF Map Key" is basically another version of the Cherry Bomb. Some of the HP claims you hear are just the pipe itself while others are with a Cherry Bomb or similar device. To me it doesn't make sense because the way I understand is if you pipe it, slip on of full system, you should be installing the CB or "map key".
Hope all that helped.
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
