more issues with the z400
Old Mar 21, 2008 | 11:00 PM
sk8emerica188's Avatar
Default more issues with the z400
had problems after putting on an fmf 4.1 system. had it fixed for a while after i jetted and put in a twin air filter. now it will only run on prime, any ideas what would cause that?
i have a dynojet kit. 150 main. needle on 3rd notch. mixture screw 3 1/2 turns out.
it was fine for about 3 rides. then last time i went it bogged out and died on me so i kept trying to start it and it wouldnt. then i put it on prime and it ran so i tried putting it back to on and it died out again.
Old Mar 22, 2008 | 11:16 AM
QWODER's Avatar
I have seen prime on atvs before but never really knew what prime does.Do you know exactly what it does to the fuel and engine?
Old Mar 22, 2008 | 04:17 PM
theCATman's Avatar
You have a vaccum leak somewhere. In the on or reserve position the gas is sucked into the carb via engine vaccum. On prime it flows free straight from the tank to the carb. That's why it runs fine on prime.
It won't hurt anything to run it on prime. Just make sure you turn the petcock to on or reserve when you haul the quad on a trailer or truck, otherwise gas could overflow from the carb.
Old Mar 22, 2008 | 05:59 PM
warrior226's Avatar
Yeah, if my Z sits for awhile without starting it, I have to put it on "prime" for it to start. Half the time I forget to put it on "run" and ride it on "prime" and never had any problems.
Nice pic of the wife there CATman [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 22, 2008 | 11:08 PM
its weird tho. it only does it sometimes. like i rode today and it was fine on the on position. only probably i had today was it bogs out when i dont rev the gear out before i go into the next one.
anyone know what that means? must be a a jetting problem, but does anyone know if it means im to lean or to rich?
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Jul 15, 2015 02:07 AM
Unzzy66
Jul 11, 2015 10:01 PM
yambam13
Jul 4, 2015 01:49 PM
