1986 Suzuki Quadrunner LT250E
Old Apr 1, 2008 | 06:29 PM
reddog1000's Avatar
Default 1986 Suzuki Quadrunner LT250E
The carb is leaking gas from the overflow at the bottom of the carb. Can I fix the problem by removing the bottom of the carb without taking it off the quad? What is inside the overflow chamber? Does anyone have an expolded picture of the carb for this model?
Old Apr 1, 2008 | 08:34 PM
yamaharap's Avatar
the needle might be stuck but when my wheelers did that i just poured a little bit of this stuff called tune up in a bottle in with the gas and it stopped the problem
Old Apr 2, 2008 | 04:23 PM
reddog1000's Avatar
Thank you very much. I sprayed WD40 into the overflow and it worked. I have bought can of Wynns carburetor cleaner to add to the gas also.
Thanks again for replying.
Dammar
Apr 20, 2016 06:03 AM
merryman
Sep 19, 2015 03:15 AM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
phummer3210
Sep 11, 2015 03:47 PM
Sep 1, 2015 11:59 PM
