Starting Problam
Old Apr 1, 2008 | 09:35 PM
K2parts's Avatar
Default Starting Problam
I have bought an 2004 ltz400. very strange I can pull start it with another atv. But it wont start with the starter. no problams cranking over. Problam getting worse. now it wont start at all.
Old Apr 2, 2008 | 03:09 PM
OLDSCHOOLQUAD's Avatar
Could it be just that the starter was going bad and finally bit the dust. Does it make any noise at all when you push the ignition button? If it makes a slight humming noise, it's probably the starter. Do you have an emergency pull start on your quad?
Old Apr 2, 2008 | 04:28 PM
hondabuster's Avatar
Could be tight intake valves. Very common on this motor. The intakes tighten up, and the compression drops way off.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
