Rear end differential fluid?
I will be changing out the fluid on the back axel of a 2004 Suzuki Z250. How much fluid do I add? I know on most autos you just fill it till it leaks back out the fill hole.
What type of fluid should I add? I assume the drain plug is under the the skid plate.
thanks in Advance,
John
thanks in Advance,
John
