cold starting problem
Old Apr 6, 2008 | 08:16 PM
ozarkeun's Avatar
Default cold starting problem
i have a 87 lt300e when i first try to start it in the morning it turns over but wont start with or without choke but i shoot a blast of starting fluid in it it starts right up after it warms up it starts everytime i put a new spark plug in it but it just doesnt like the cold any ideas
Old Apr 6, 2008 | 09:02 PM
BAIR's Avatar
Point - it is a 1987 Bike, everything is getting old and a poor spark is possible, old wires with cracked insulation will reduce your power to the plug etc.
From your description - I would suggest that you change the spark plug wires.
(wiring harness), as well as your ignition system and see what difference it makes.
Good Luck!
Old Apr 6, 2008 | 09:49 PM
JustRandy's Avatar
Check the intake valve lash. Cold starting problems is a symptom of having too little lash in the intake valve. You also could have plugged jets n things like that. And the electrical system could be on the weak side, especialy where coils of wire are involved.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
garyt1975
Jun 5, 2015 08:53 AM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
