Eiger Clutch Kit Problems?????????
Old Apr 9, 2008 | 09:17 AM
Phil05Eiger4x4's Avatar
Default Eiger Clutch Kit Problems?????????
I got it all back together tonight put oil in and started up. started up ran but with like a clicking noise and if i tap the gas you hear a grind noise,(more of a rattle noise maybe )sounds like something is lose but you wont hear it until i tap the gas.. then if i put it in gear why its running it will straight jump ahead and then shut off. i mean it pushes it forward pretty good then shuts off then its pretty tight to get back into neutral. heres the when i was trying to put the housing back on took me like 4-5 hrs alone man was trying to give it a little blow with a rubber mallet never worked could never get it to seat right but i take off that directional bearing went on fine. the bearing that fits on the clutch basket i believe, the one that falls off when doing all this. So i knew it was something wrong with the bearing going on. im assuming with it saying this side out means that its facing me on the clutch part not the housing?>????? but anyways i did it with my borther in law and finally got it on but right before that i put that directional bearing bvack on and it was hard to get on and it would turn but barely i had to actually twist it to turn it. i dont know if thats my problem? and i need to get a new one but its just way to frustrating ......all this work and blah......a bit frustrating but oh well **** happens i guess...... i dont really want to pay a shop to do it because i know i can do it myself and save some cash.........thanks again
its an automatic with epi kit
Old Apr 9, 2008 | 12:41 PM
anyone????
Old Apr 9, 2008 | 08:29 PM
Old Apr 9, 2008 | 09:35 PM
LimpingLizard's Avatar
Phil, sent you a pm.
skinnyr6
Aug 25, 2023 02:18 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
cornermike
Jul 8, 2015 11:44 PM
