suzuki lt230s
Old Apr 14, 2008 | 04:54 PM
krazzietrain's Avatar
Default suzuki lt230s
i have a 1987 suzuki lts230s that is running in a weired kinda way at first my main coil broke and i replace the entire stator coil with one i had it ran good for about a week and now some days you go kick it and it has spark but only for about three or four kicks. then other days you kick it and it doesn't have spark period.
here is what i have tried, i put the spare flywheel i had on it and it ran for a day or two so i thought the flywheel was bad so i found a racing flywheel one on eBay for $100 put it on and didnt help so i then tried putting the old pickup coil on it and it got spark again. but only for a day or so. and it would only have it for a few kicks
so if anyone can shine some light on this issue i would appreciate it verry much so
thanks in advace [img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 14, 2008 | 09:02 PM
500quadvalley's Avatar
take pickup off and ohm it with ohm meter keep leads hooked to meter and slide screwdriver across pickup and see what it does it should open and close evenly every time.
Old Apr 15, 2008 | 10:01 AM
ok i will try this and get back to you if i ohm it with out sliding the screwdriver then it ohms good but as we all know it doesnt mean it is
thanks for some info
lonerider856
Oct 13, 2023 03:45 PM
VABrute
Jan 6, 2016 07:39 PM
merryman
Sep 19, 2015 03:15 AM
jsmit116
Sep 18, 2015 10:34 PM
Sep 1, 2015 11:59 PM
