lt-f300 help
Old Jun 26, 2008 | 01:21 PM
strawboss's Avatar
Default lt-f300 help
i have a problem with large amount of raw gas in crank case (full)
i've taken the carb of and checked float by pumping gas in
with mustard thing with gas line and taperd spout and float shutoff
the float shows no sign of wear i have changed oil and put carb on
and it will be ok for a short while
any help
thanks strawboss[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 26, 2008 | 02:06 PM
lileigerthatcan!'s Avatar
get rid of the facrtory petcock valve and put one on with an actual off position. I have heard of alot of suzuki's doing this because the factory petcock never really turns off.
Old Jun 27, 2008 | 07:14 PM
akarotten's Avatar
I had same problem with my ltf-250 94 mod.Bought and installed new carb kit,problem was solved.
Old Jul 4, 2008 | 03:25 PM
strawboss's Avatar
thanks for the help i took the carb apart and adj the float
and found that the (stater (enricher) plunger as it's called
was missing if this was the problem it didn't foul the plug.
it will be about two weeks until i get the parts and will post back
strawboss
donkeydoc
Aug 6, 2001 11:43 PM
