2000 ltf300f Doesn't Start
Old Jul 7, 2008 | 06:52 PM
gskltf300f's Avatar
Default 2000 ltf300f Doesn't Start
Hey guys,
My 2000 ltf300f does not start. I have owned it since new and have never had it not start. First, it turns over like normal. That is, the battery is charged and the starter works. I pulled the plug and rested it against the cylinder and it sparked. But I am going to get a new plug since the one that is in there has never been changed. The color of the plug is black as in quite a bit of carbon. Note that I pulled the air filter when I tried to start it. So I think I have eliminated electrical (spark) and air as the problems.
When I pulled the plug after trying to start it the plug looked try like it wasn't getting any gas. I looked online and it shows an optional fuel pump. I don't know if mine has a fuel pump or not but I will check.
Does any body know if there is a fuse box? If so where is it located?
Any body else have any suggestion about what to look for as possible causes of not starting???
Thanks,
Gary
Old Jul 7, 2008 | 09:03 PM
86trx200sx's Avatar
yes there is 2 fuse boxes on a bracket but your carb looks too intricit for me to tell if there is a fuel pump in the carb or not sorry.....i would spray some ether down the carb and try to start it and if it does then there is a clog in the fuel system some where or (if there is a fuel pump) the fuel pump needs attending to..and if it doesnot start then that opens a whole nother can of worms.....this site might help you click here.....but try ether to see what happens
green giant
Jul 13, 2017 12:07 PM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
wbfjim
Jun 8, 2015 06:20 PM
1000gade
May 27, 2015 12:37 PM
