Eiger starting problems
Old Aug 22, 2008 | 05:03 PM
Smoke2's Avatar
Default Eiger starting problems
I push the start button and nothing happens. Then I tried to pull the rope a couple hundred times still nothing, I'm worn out. When I turn on the headlights they are bright and the battery is full. The fuse is good next to the relay. Are there any in-line fuses from the ignition switch to the starter and doesn't the engine start with a bad relay when pulled---what else am I missing?
Old Aug 22, 2008 | 05:38 PM
Smoke2's Avatar
I found the problem
the off - run switch wasn't grounded
thanks
neilbedwell
Nov 10, 2018 11:02 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
