86 quadsport drive chain size & other questions
Old Sep 13, 2008 | 03:31 PM
corvette535's Avatar
Default 86 quadsport drive chain size & other questions
hello all. I was wondering if the standard 520 chain is to be used with a stock 12T front sprocket and a 39T rear...can i just use a new stock chain?
also, how mcuh oil does this thing hold? i believe it is 1.5qt. but not sure.
thanks!
matt
Old Sep 13, 2008 | 04:07 PM
270quadsportguy's Avatar
almost 2 qts ud be bettwer off getting a oring chain i never had any luck with non o ring. make sure the swing arm bearings are not loose and also make sure the chain has slack or the swingarm bearings will get wasted fast. As long as u get 90 link chain u should be goot usually u have to grind out a few links as chains are usually long
Old Sep 13, 2008 | 04:31 PM
where can i get that chain? also, how much slack ? thanks
clsharky
Jul 13, 2015 02:07 PM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
200es
Jul 10, 2015 09:09 AM
D-Hagz
Jul 4, 2015 02:19 AM
