How to adjust chain on a lt185
Old Sep 22, 2008 | 11:51 AM
safooma230s's Avatar
Default How to adjust chain on a lt185
Is there a way to tighten the drive chain on a lt185? There is no rear suspension and the chain is fully enclosed. I took off the chain case and noted that there is some sort of chain tensioning wheel, but I do not see a way to adjust it? Heck, I don't even know how to measure whether or not it NEEDS tightening.
Thanks!
Old Oct 8, 2008 | 05:03 PM
Does someone that has a manual look this up for me? thanks!
Old Sep 1, 2009 | 10:48 PM
invisible4good's Avatar
Default chain tighten
hey if you still need help... i might be able to assist. when ur lookng at ur chain u see a gear that kinda sits in the middle between the rear sprocket and the clutch sprocket.... take off the chain, loosing that middle sprocket, and ppush it up a noth. tighten it down and put the chain on.... wala
Old Sep 3, 2009 | 05:33 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
I can't imagine a chain adjustment process that would require you to take the chain off to tighten it.
If you can find a factory service manual, or even a clymers, it will tell/show you the process. It's a shame I eBayed my old LT125/185 service manual last year.
Old Jun 27, 2021 | 08:59 AM
preszy's Avatar
This is almost 10 years later but I found this page I am hoping to help anyone else who stumbles on to it, I tried it yesterday you have to pull off a snap ring pull the whole thing off and move it up one gear on the shaft it’s hard to explain but if you go and take it off you will see. That can also determine if it needs to be tightened if you can’t get it to go up one you need to wait.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
goosemasterkl
Aug 23, 2015 11:36 AM
