LTZ 90 Help Please
Old Oct 31, 2008 | 07:57 PM
rkb2710's Avatar
Default LTZ 90 Help Please
I have 2008 LTZ 90 for my daughter, which is 10. After 2 months, daughter wants it to be faster. We are getting a top speed of 18 MPH. Is this the norm. Or is there something I can do to it.
Thanks
Old Oct 31, 2008 | 10:43 PM
Outof$'s Avatar
Have you removed the washer in the cvt yet?
Old Oct 31, 2008 | 11:33 PM
rkb2710's Avatar
Thank you. I haven't removed it. Would this be something easy for a novice. Thank you again for reply.
Old Nov 1, 2008 | 08:45 AM
Outof$'s Avatar
yeah, it is easy. You just need an impact wrench to remove the nut. It shows it in the owners manual. You will be happy with the speed change. Let her get used to that then get prepared to spend some money for more speed.
Old Nov 2, 2008 | 01:56 AM
rkb2710's Avatar
Thanks, I will try it
Old Nov 4, 2008 | 01:31 AM
rkb2710's Avatar
I'm really a novice. Why do you need the impact wrench and not a regular wrench.
Thanks
Old Nov 4, 2008 | 10:04 AM
LT80's Avatar
LT80 Expert
Cuz there is no way to hold the clutchs from turning w/regular wrenches.
ALTHO, it can be done with a big enough set of slip joint pliers to hold the front outer clutch face.. Care must be taken as to not break the face..
Old Jan 1, 2009 | 02:23 AM
rkb2710's Avatar
I finally got around to taking it off, much faster. Thanks
Old Jan 4, 2009 | 02:31 AM
rkb2710's Avatar
So, I can spend some money and make the LTZ90 fastier?
Old Jan 4, 2009 | 02:33 AM
rkb2710's Avatar
So I can spend some more money and make it faster
