1995 king quad
Old Nov 4, 2008 | 12:46 AM
Turtle2323's Avatar
Default 1995 king quad
Hi, I have a 1995 king quad it has no spark i have replaced the spark plug checked the kill switch because i am getting it to turn over but with no spark and i have replaced the coil and also have checked all my grounds. what should i do to figure this out?
Old Nov 4, 2008 | 09:47 AM
OLDSCHOOLQUAD's Avatar
Have you checked your intake valve's lash? Mine turns over also but does not sound like it is getting spark. I have learned that it has been my intake valve that was all junked up and not allowing for enough air to enter the chamber (cylinder) to allow for "explosion". Here comes the funny part...
So I ride my 95 kq every day anyway. Here's how I do it. Even though it sounds as though there is no chance of starting, I continue to try with my idle (mixture) way lean, almost to the point of screwing itself out of the carb (but don't let it do that). The whole time I am giving my starter hell, I am pumping the throttle constantly. Usaully after about five minutes of trying, my battery charge dies. That's when I grab my trusting 300 amp jump starter and hook it up. Every time, without fail (knock on wood) it will go from sounding like it has no spark, to igniting and starting. I then have to warm it up a little before turning my idle back to an acceptable level so that it may stay idle without the help of the throttle.
Crazy reasons why this makes no sense:
-I should be flooding the engine, but I am not.
-After the initial hell starting, it will fire right back up without any problems as long as the engine is still warm. Makes no sense, makes it sound like a fuel delivery problem, but isn't.
-My starter is holding stong after six months of this "initial" starting process. I know, it should be burnt by now.
Anyway, might be your problem, might not. But give it a try, in all sometimes it takes me twenty-thirty minutes to get it started, but then she rides great all day long without any problems. Other times, it will start up in five minutes of trying.
Good luck, love my kq, but hate starting it, ha ha.
Old Nov 4, 2008 | 01:29 PM
kuzzuki's Avatar
Hi
As you guys are runnig the same quad as my self, would you know what the lash on the valves should be???
thanks
Bovien
Old Nov 5, 2008 | 12:38 PM
mustangstephen's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: kuzzuki
Hi
thanks
Bovien</end quote></div>
Valve clearance 250 2wd & 4wd, and 300 kq
Intake 0.001-0.003 in
Exhaust
250cc 0.003-0.005 in
280cc
1991-1994 0.005-0.007 in
1995-1998 0.007-0.009 in
Frisky2050
Apr 9, 2020 11:19 AM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
