suzuki lt125 carb help
Old Nov 11, 2008 | 12:44 AM
ford4x4's Avatar
Default suzuki lt125 carb help
hi i just got a lt 125. i cleaned the carb but am now wondering where the fuel hoses go. there were only two hoses when i got it but there are 4 spots for hoses so i am kinda confused. coming off the fuel pump is : the hose directly across from gas tank hose, i have that hooked onto the fuel bowl on the left side. the other hose comes from the front of the fuel pump and i am assuming it is a vacuum line and i have that hooked to the front of the carb right where it attaches to the block.
i dont know if this is right or what.
Old Nov 14, 2008 | 05:56 PM
ford4x4's Avatar
anyone? right now i have a vacuum line from the intake to the fuel pump. and a line from the pump to a T, where one line goes to the neck of the carb and the other goes to the fuel bowl.
we can get it running on starter fluid and itll run for a sec and die. seems like its not getting gas but the lines have fuel in them. also fuel drips from the bowl so it seems like its flooded.
Old Nov 23, 2008 | 08:42 PM
ford4x4's Avatar
anyonee??
Old Nov 23, 2008 | 09:40 PM
Sisco1957's Avatar
It's been so long since I worked on a 125 I'm not sure but I know the vaccum line from the pump has to hook to the intake. The carb has some vent lines also. I don't remember the fuel line having a T. Sounds like You may be putting fuel into a vent or overflow port causing it to flood. Hope this helps.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Jul 15, 2015 02:07 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
