Need Help ASAP
Old Nov 21, 2008 | 07:18 PM
labguy's Avatar
Default Need Help ASAP
Hey guys,
I have a ride scheduled for the fam tomorrow and need some help. I have an LT80 (2 stroke) and it starts and runs fine. I noticed that a good amount of 2 cycle oil was "spitting" out of the exhaust. Does anyone know what causes this? The oil built up so much that it was running down the end of the exhaust. Any and all help will be appreciated.
Old Nov 21, 2008 | 07:32 PM
Stoopidbot's Avatar
Probably time to change your exhaust packing. It's most likely soaked.
Old Nov 21, 2008 | 07:37 PM
Bobbyg's Avatar
you may want to check your gas/mix is it old or to rich and is it jetted?
Old Nov 21, 2008 | 07:38 PM
labguy's Avatar
Can you tell me where in the exhause thats located in? Will it hurt the quad if my nephew rides it once before I change it? Thanks for the help
Old Nov 21, 2008 | 07:39 PM
labguy's Avatar
Bobbyg: Its oil injected. As far as I know, everything is stock. Bought it used and the previous owner made no mention of that. Thanks for the info.
Old Nov 21, 2008 | 08:00 PM
labguy's Avatar
UPDATE: I pulled the drain plug out of the exhaust and it poured out lots of oil. Thanks for the help.
Old Nov 21, 2008 | 09:01 PM
cherokee99's Avatar
wow, that much oil? sounds like your oil injectir may be over pumping oil
Old Nov 21, 2008 | 11:33 PM
Stoopidbot's Avatar
I'm thinking it is probably stock packing in the exhaust. There should be some bolts or screws of some kind on the tip of the exhaust. You take that off and there is a guaze kind of stuff in it. Every bike shop will carry the packing replacement.
This just started? Are you having performance issues?
If there is no performance problem, you SHOULD be ok for one more ride. Just don't be behind him.
slowgsxr97
Sep 8, 2015 07:33 PM
400H0
10
Aug 20, 2015 07:34 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
mitchxc700
Aug 10, 2015 09:26 PM
Daryl Devine
Technical and How-To Articles
Jun 8, 2015 08:59 AM
