ozark brake light always on
what is likely causing the light to stay on? each switch seems to move in and out just fine. would unplugging each switch one at a time identify the culprit? does unplugging a switch CAUSE the light to come on? no debris seems to be present in the rear switch, which certainly gets dirtier.
<div class="FTQUOTE"><begin quote>Originally posted by: bkache1
what is likely causing the light to stay on? each switch seems to move in and out just fine. would unplugging each switch one at a time identify the culprit? does unplugging a switch CAUSE the light to come on? no debris seems to be present in the rear switch, which certainly gets dirtier.</end quote></div>Check where the brake cables come in be the brake drum and lube that braket. Make sure the rear hand and foot brake are not sticking(lift up on each). Worked on mine.
sweaver
11
Aug 18, 2015 03:47 PM
